Wharfedale W2
Sgt.Pepper
Re: Wharfedale W2
Message par Sgt.Pepper »
Et voici un extrait du livre "A Pair of Wharfedales" de David Briggs (dont le grand-père était le cousin de Gilbert Briggs, créateur de Wharfedale).
The spring 1959 offerings included three cabinet systems, the W2, W3 and W4 (all based around a new 12" bass chassis, the WLS/12) and the AF12 reflex cabinet designed for the 12" units with foam surround but especially for a completely new twin-cone chassis, the Coaxial 12. The three cabinet systems were arguably the first products with a modern feel and the first thought-out range or 'family' of loudspeakers in which performance for a chosen retail price was optimised whilst striving to minimise the size, particularly the occupied floor space. They ware, as the names might imply, respectively, two-, three- and four-way systems. Raymond Cooke, covinced well beforce he joined Wharfedale that a 15" speaker in a large enclosure was not essential for really good bass reproduction (the received wisdom at that time) provided some loss of efficiency was accepted, had the incentive to prove his theory. He was, however, assisted by the fact that speaker efficency was becoming less of an issue ; as amplifiers improved, speakers did not have to do their best to preserve every precious watt of output so efficiency was becoming a tradable commodity.
The common bass unit in all three new Wharfedale systems was the WLS/12, a 12" chassis with a heavy cone, high compliance suspension (resign-impregnated, moulded fabric treated with synthetic rubber to make it airtight) to give improved linearity and an expanded polystyrene diaphragm, known as a 'bung', which fitted inside the cone to provide extra stiffening and a degree of acoustic filtering. Although not described as such, the suspension was effectively 'roll surround', a precursor of things to come. The result was a bass resonance in all three cabinets of 30 Hz, undistorted at 4 watt output.
A noter que Raymond Cooke, fondateur de Kef, avait été embauché en 1955 chez Wharfedale comme "Technical Manager".
EDIT : les W2 étaient toujours au catalogue en 1964, sans que des modifications aient été apportées, ou tout au moins annoncées.
Sgt.Pepper
Re: Wharfedale W2
Salut Damien,
Voici encore quelques documentations, cette fois-ci de 1961 et de 1964.
1961 :
1964 :
Et enfin, une pricelist de mars 1964 :
Modifié en dernier par Sgt.Pepper le sam. 30 mars 2024 11:45, modifié 1 fois.
Sgt.Pepper
Re: Wharfedale W2
En revanche, c'est curieux, lorsque je survole la documentation en ma possession, je ne trouve pas trace d'un haut-parleur 12" avec aimant alnico et plaque de polystyrène. Et d'ailleurs, la documentation du WLS 12, qui est censé équiper la W2, ne fait pas état d'une membrane de polystyrène.
Le document qui suit, de 1962, parle de ladite technologie, mais elle ne concerne a priori que le W12/RS/PST, qui a un aimant céramique.
polystyrene 1962.jpg (28.96 Kio) Vu 5553 fois
Le W12/RS/PST étant le suivant :
La dernier document fait référence au Cabinet Handbook écrit par Briggs. Je vais jeter un oeil pour voir ce qu'il y est dit à propos de la membrane en polystyrène.
Sgt.Pepper
Re: Wharfedale W2
Voici voilà un extrait du livre Cabinet Handbook dont il est question plus haut :
polystyrene dia 1.JPG (50.43 Kio) Vu 5529 fois
polystyrene dia 2.JPG (120.63 Kio) Vu 5529 fois
Sgt.Pepper
Re: Wharfedale W2
Damien, ton haut-parleur de grave serait un PST12/RS, et non un W12/RS/PST, si j'en crois la publication dans le Wireless World auquel Gilbert Briggs fait référence dans son Cabinet Handbook :
Re: Wharfedale W2
Waouh !
Merci pour ce travail de recherche et de documentation Nicolas!
