Le 1030 :
Le sd180 :
Polarity: NPN
Maximum collector power dissipation (Pc), W: 50
Maximum collector-base voltage |Ucb|, V: 150
Maximum collector-emitter voltage |Uce|, V: 80
Maximum emitter-base voltage |Ueb|, V: 6
Maximum collector current |Ic max|, A: 6
Maksimalna temperatura (Tj), °C: 150
Transition frequency (ft), MHz: 12
Collector capacitance (Cc), pF:
Forward current transfer ratio (hFE), min: 50
Il n'y a que le Ueb qui est inférieur, qu'en pensez-vous ?Polarity: NPN
Maximum collector-base voltage |Ucb|, V: 80
Maximum collector-emitter voltage |Uce|, V: 60
Maximum emitter-base voltage |Ueb|, V: 7
Maximum collector current |Ic max|, A: 5
Maksimalna temperatura (Tj), °C: 125
Transition frequency (ft), MHz: 10
Forward current transfer ratio (hFE), min: 30
Noise Figure, dB: -
