Audio Research SP-3A 1
- SidSmith
Re: Audio Research SP-3A 1
L'interface entre le filtre actif et le préampli peut-être ? Ou entre le préampli et les ampli.
Ce qui est perturbant c'est que cela semble «suivre» le préampli d'un système à l'autre.
Tout en fonctionnant parfaitement, il est possible que certaines pièces passives limitent encore la transparence de l'appareil.
- Jo775
- SidSmith
Peut-être que la façon de distordre des préampli diffère. Voici un extrait du document «The Venerable Triode» de Nelson Pass :..... mais une scène sonore toujours extrêmement "plate" qui n' offre pas la précision de focalisation que j' ai l' habitude de percevoir.
«[...] Depending on the load impedance and the bias point, the Triode will exhibit varying levels of 2nd harmonic and also the phase polarity of that 2nd harmonic.
You can have more or less of positive second, negative second.
There is a point in the middle where the 2nd harmonic disappears, leaving 3rd and perhaps some higher harmonics. This is where the measured distortion will
generally be at it's lowest point, and popular with designers looking for the lowest distortion number. But not all designers are necessarily looking for the
lowest number. Some want some small quantity of 2nd harmonic to “sweeten” the sound or perhaps to make it “warmer”. This is commonly understood among
audiophiles, who routinely use tube preamps with solid state amplifiers to get this effect.
What is not common understood is that there is a difference in sonic signature not only in the amount of 2nd harmonic distortion, but also between positive and
negative phase. [...]Modest amounts of negative phase 2nd tends to create greater depth and space to the sound stage, with the illusion of better imaging. Positive phase 2nd puts
the perception midrange closer, with a little more in-your-face presence.»
Il faut cependant être prudent avec ces constats, ils proviennent de ses expériences personnels et professionnels et non de recherches empiriques.
Ce pourrait-il que dans leur quête d'abaisser la distorsion globale, AR est choisi d'une part de limiter le taux de 2e harmonique autant que possible, abaissant la distorsion mais permettant une plus grande place aux 3e harmoniques, et d'autre part que le caractère du son ait été altéré de sorte de laissé place aux 2e harmonique de phase positive ?
Dans ces conditions il est normale que la signature sonore du système ait été altéré.
- Bertrand
Jean a effectivement essayé des tfk sur le SP3. Je ne pense pas que les points de fonctionnement choisis aussi bien par Saul Marantz et son équipe pour le marantz 7c que ceux choisis par AR favorisent des distorsions par harmonique paires, en phase négative ou positive d'ailleurs. Ce sont deux appareils conçus pour être "droit" avec des taux de distorsion très bas, équipés en plus avec des tubes eux aussi particulièrement linéaires (par rapport aux autres ECC83). Mais je me trompe peut-être...
François H-D
comme l'a dit Jean-François dans un de ses posts, je crois plutôt qu'il s'agit d'un problème d'optimisation d'un système précédemment réglé avec le Marantz. Et personnellement j'irais chercher du côté du rapport d'impédance entre sortie PA et entée filtre actif.
J'aurais bien une solution à proposer, mais je ne pense pas que l'alim du SP3 l'autorise.
Cordialement,
Cordialement,
- 6336A
Les impédances de sortie du marantz et de l'arc sont suffisamment faibles pour attaquer le ta-d900 (aux alentours de 600 ohm pour le marantz, un peu moins pour le ARC)
Par contre, même si dans le milieu audiophile il est souvent dit que les schémas sont très proches, AR étant très inspiré par son aîné, on se rend compte que ce n'est pas tout à fait exact...
Dis toujours, ça peut être intéressant...J'aurais bien une solution à proposer, mais je ne pense pas que l'alim du SP3 l'autorise.
Modifié en dernier par 6336A le sam. 31 août 2019 13:22, modifié 1 fois.
François H-D
Je dis, mais ailleurs...
- Klemp
Le SP-3, modifié comme indiqué précédemment, fonctionne réellement très bien avec tout ce qu' il faut pour offrir beaucoup de plaisir musical ….
Mais ….. même sur le système Orthophase, avec ses électroniques associées, je retrouve la même sensation de "platitude" … et pour le situer par rapport à d' autres préamplis, je dirai qu' il est au dessus du Sony TA-E88B sur des critères de dynamique, de timbres, de précision …. et inférieur au "vieux" JBL SG-520 (quand ce dernier fonctionne) sur à peu près tous les critères, surtout sur celui de s' effacer devant la musique et offrir une forme une liberté d' expression .... paramètre qui, pour moi, est complètement essentiel.
Je ne cherche pas à expliquer le "pourquoi du comment", mais c' est ce que je constate et le système Orthophase est redoutable pour cela.
Je réserverai le SP-3 pour le système Magnepan avec le filtre EC-3 et d' autres électroniques. Il devrait être fonctionnel à l' automne.
Merci François pour ta proposition de solution
François H-D
Bonjour Jean, et tous,
je ne pense justement pas que cette solution soit applicable simplement au SP3 (alim filament passive et 2 tubes en série comme sur le SP6?), sans parler de la réserve émise par Jean-François...
Cordialement,
Cordialement,
- SidSmith
IL faut faire attention, je crois que Sid Smith avait compris que la suppression complète de la distorsion était impossible et que si il était pris pour dealer avec de la distorsion, il préférait une dominance de la distorsion de seconde harmonique. Je crois qu'un article de la revue du son parlant des Model 9 relate la dominance des harmoniques paires pour ce dernier, surtout la 2e.Bertrand a écrit : ven. 30 août 2019 23:41 Bonsoir,
D'ailleurs, Sid Smith est le premier à reconnaître que tous ses circuit audio ont une même signature sonore, du Marantz Model 1 au Grado HPA-1.
Et comme le souligne M.Pass, le type et la quantité de distorsion qui s'exprime affecte l'impression psychoacoustique. C'est pourquoi sur son ampli SIT-1 il est possible d'ajuster le taux de distorsion selon ce que l'on préfère à l'écoute.
En même temps c'est pour cela que l'on essaye puis vire des composants d'un système.
- 24 Réponses
- 78876 Vues
- 8 Réponses
- 31501 Vues
Dernier message par 6336A
- 2 Réponses
- 193 Vues
Dernier message par Thierry L
